remove the line you see going to the top of the egr. crank the truck and stick a straw or tube over that hole. suck on the other end of your device. if the idle changes you need a new egr.
* The DPFE (differential pressure) sensor is faulty and needs to be replaced
* There is a blockage in the EGR (most likely carbon buildup)
* The EGR valve is faulty
* The EGR valve may not be opening due to a lack of vacuum
