Costing me a Fortune
Two things. When you clean the MAF, it is imperative that you use an electronics cleaner so that there is no residue, or you defeat the purose of cleaning. Second, have you cleaned the IAC? Here is some info.
https://www.f150online.com/forums/19...ough-idle.html
Take the truck out for a spin at hiway speeds for about 15 miles. Bring it back where you can jack it up. Spin each wheel. Look for one or more that doesn't keep spinning. The brake system may need maintenance. Look for any exhaust leaks at the manifolds. Any leaks will cause the O2 sensors to read wrong. Make sure you are not running tires with too low of pressure. If the tires are not the original size, mileage will suffer via the different circumference. If not the original size, max out the tire pressure according to the info on the sidewall. Check to make sure you have no codes stored. If you have any, fix them.
it sounds to me like the truck needs the wheel bearings re packed, or there's a brake dragging (maybe the parking brake)
no reason to keep throwing money at something, is the truck throwing any codes?
what size tires does this truck have? what gears? do you drive it gently or you drive it like you stole it?
The cleaner I used is strictly a cleaner, not a lubricating cleaner. Made sure.
them, at either end. Checked it out. No exhaust leaks either. The tires on it were not the original size when I bought it, but the mileage started dropping off before I replaced them, so I don't believe that is the problem. I tried running the tires at about 40# when I bought them, all it did was wear the centers out of the tread. No codes showing, had it checked on a OBD reader.
Maybe the 4X4 has sealed wheel bearings. I've never owned on so I don't know.
There was more than one factory size jethat, -at least two for sure. Mine are posted in my sig. It's always been lol. Yea , but it's a 4x4 off road/ tow package, - E4OD/4R100. Not sure what model the OP has ?
Something wrong there. Can't remember if they ever used 16.5 wheels on an F-150 or not but they definitely didn't in '98. Looked it up and they only show 16in and 17in as optional. Can't imagine where they came up with wheels that would fit that truck in a 16.5 wheel. And I have never heard of wheel bearings that were sealed on an F-150 before the '04 new body 2WD on the front. Are you sure Johnny Cash didn't build this truck?
The truck w/16's was a 98 2wd reg cab/ short box w/4.2L.
Had an 01 for a little while, but iduno what it had on it ? They were black, if that helps
Maybe I'll it up after my second pot
sion parts, tie-rods, etc., are sealed. I WISH I could grease them. Maybe that's just the 4wd model. I can't say. I didn't get maintenance records with the truck, so I don't know what the original owner did or didn't do.
