Oil filter..oh noooooooooooo!
Old 09-08-2010 | 09:43 AM
jethat's Avatar
Originally Posted by jbrew
That's nice Patrick, I haven't seen those yet.
I don't know what's so hard about changing the filters, easiest filter I ever changed -
I have that same deal. Piece of cake. 10 minutes to change the oil.. My vans easy to its right on the bottom of the engine. Even for an old dude like me who hate crawling around on the ground its easy.. Hard to take it in when its so easy.
  #47
Old 09-08-2010 | 10:59 AM
Originally Posted by Jon Bourget
That might work for my PWC aplication. With the help of a flex extension and or a knee joint ratchet. Unless I can recruit the help of some little person wrestler.
not sure what PWC is, but they also have a smaller one for "import cars" so make sure you're buying the correct one for your setup
  #48
Old 09-08-2010 | 12:21 PM
stx2006's Avatar
Personal Watercraft AKA (JETSKI)
  #49
Old 09-08-2010 | 06:38 PM
arubba's Avatar
Yes Bucky919, that is the oil filter wrench I purchased and it works great. I see a number of folks mentioned "Strap Wrenches" which I own but could not see a way in the tight fit area to use. I use the the "Auto Adjust Filter Wrench on a long extension......
  #50
Old 09-08-2010 | 11:02 PM
[IMG]
Gotcha. just wasnt able to come up with the acronym this morning
you would probably want to get the smaller one for the jetskit, and the bigger one i linked for the truck
  #51
Old 09-08-2010 | 11:28 PM
Fordoor's Avatar
My filter was put on by Shrek
I bent the hell out of it getting it off on my first oil change.
easy as pie now
  #52
Old 09-09-2010 | 03:46 AM
code58's Avatar
The metal strap wrench (K-D) is a good one and I've never bent it even taking the 1st (factory installed) filter off. It's easy to get to from the top with the intake tube out of the way. I changed the filter the 1st couple of times from the bottom and decided that was stupid. Much easier from the top. The flexible handle on the K-D allows you to clear the engine from the top. I wouldn't use the cheap imitations though, pretty sure you could bend them.
  #53
Old 09-09-2010 | 05:08 PM
johnkraus's Avatar
can the heads be removed without removing the engine ? 2005 f-150 5.4 supercab.
  #54
Old 09-11-2010 | 02:56 AM
code58's Avatar
The short answer is yes... you just have to remove the cab. Done all the time in the dealerships. I know that's not the answer you wanted to hear. The short answer is still yes... without removing the cab... but you aren't likely to come out of that one smiling! Good luck.
  #55
Old 09-16-2010 | 10:14 AM
craneman's Avatar
Is it cheaper if they leve your truck with greasy armrests and scratched bodywork?
I don't have that problem go some place else. I had a minor issue one time and they eat the service no charge.
  #56
Old 09-16-2010 | 11:59 AM
Woodiedl's Avatar
I am getting ready to do that myself. I don't plan on removing the cab.
But if Code is correct from all I have read I will not be smiling doing it, Just after it is finished and driving a quiet truck again..
One tip is to take air out of the front tires to help lower the truck and use a brench, like at the ball diamond to stand on to get up higher.
Another from a timing cover thread is to use RTV silicone on all the t-joins (I think that is the correct term) so that the oil doesn't leak out from the timing cover.
Here are a couple of links to threads to get you started.
https://www.f150online.com/forums/v8...eplacment.html
https://www.f150online.com/forums/v8...d-gaskets.html
https://www.f150online.com/forums/v8...t-else-do.html
There is also a .doc instructions on how to change the heads on one of the forum threads.
I have a copy if you want it.
Just PM me your e-mail addy.
Good Luck.
  #57
Old 09-17-2010 | 06:30 PM
Fifty150's Avatar
http://www.youtube.com/watch?v=n8B9erdk0go&feature=fvw
<object style="height: 344px; width: 425px"><param name="movie" value="http://www.youtube.com/v/n8B9erdk0go?version=3"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/n8B9erdk0go?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></object>
  #58
Old 09-17-2010 | 07:36 PM
JMC's Avatar
JMC
I speak french, are they hiring?
  #59
Old 09-17-2010 | 08:37 PM
scott_05_FX4's Avatar
stick a screw driver in it and turn that way
  #60
Old 09-20-2010 | 01:21 PM
danjkelly's Avatar
Their explaination (excuse)
The dealership uses a fancy oil filter wrench from Snap On
Because it is under exhaust, the oil filter gasket heats up and binds the filter to the block.
They say it is a booger bear,
Guess I'll track down Snap On
Quick Reply: Oil filter..oh noooooooooooo!
