Oil filter..oh noooooooooooo!
Old 10-02-2010 | 07:06 PM
m_melen's Avatar
just go to autozone and buy an oil filter wrench or similar tool. theyre cheap. i've got like 4 different tools for different styles and difficult locations of oil filters.
  #62
Old 10-02-2010 | 07:14 PM
m_melen's Avatar
Originally Posted by danjkelly
The dealership uses a fancy oil filter wrench from Snap On
Because it is under exhaust, the oil filter gasket heats up and binds the filter to the block.
They say it is a booger bear,
Guess I'll track down Snap On
don't need snap-on. try harbor freight. saved you 30 bucks. leave snap-on to people who use tools for a living unless you're made of money.
  #63
Old 10-02-2010 | 08:07 PM
AZFX4's Avatar
Harbor freight has those same 3 prong style wrench attachments that someone else listed on here for cheap. Cant beat it.
  #64
Old 10-05-2010 | 08:50 PM
BajaSuperCrew's Avatar
Use the big pliers style. Gets the filter off in no time every time.
  #65
Old 10-06-2010 | 07:46 AM
tradosaurus's Avatar
ACtually I used a strap oil filter wrench while the engine was warm. It took some effort but I got the oil filter off.
Now imagine how tight they put your lug nuts on at the factory?
  #66
Old 10-07-2010 | 03:50 AM
code58's Avatar
Yea, 150 ft lbs of torque. That's what it feels like the filter is put on with, but I almost always change mine cold, so it takes more to get it off. 1st filters I mean. Not only is it put on by a machine, but dry. Bad combination. I have always used a good strap wrench from the top. In 3 new F-150's with the modular, they've always been tight but always came with good steady brute pressure.
  #67
Old 10-07-2010 | 07:48 AM
Actually I checked my lug nuts when I brought my new truck home.
Probably 3 lug nuts had at least 180 ft-lb torque (maybe more).
  #68
Old 10-07-2010 | 08:31 AM
MGDfan's Avatar
Yep. Same here - perhaps it's a shipping thing. In any case, that is one of the items that's supposed to be addressed in the ridiculously inflated Dealer Prep charge.
A new one, I did tear. Had my torque wrench with me - checked 'em right on the lot
MGD
  #69
Old 10-25-2010 | 09:16 PM
BigRed89's Avatar
if you realy dont want to take it in and i understand not wanting to. i have had thi happen once and i just punched an awe through the filter and use it to twist it off worked well for me obveously put something down it makes a mess down side obveously if you still cant get it off then you have more of a problem then you started with just food for thought
  #70
Old 10-26-2010 | 04:00 AM
code58's Avatar
There are a # of filter wrenches that would take it off if it were welded on. I stuck a screw driver through the filter on my DIL's Lexus RX because the filter was so tight and difficult to get to that I COULDN'T get it off! Not even with a filter wrench. What a mess! Not only was there oil all over from the holes in the filter, then it started to tear rather then come off and I was really in a pickle. Finally got it off with a big pipe wrench. Never again will I poke a hole in one!
  #71
Old 10-26-2010 | 07:49 AM
If you attempt to take the oil filter off with the engine warm it will be easier.
Quick Reply: Oil filter..oh noooooooooooo!
