P0171
Old 10-24-2010 | 09:12 AM
MTM Ford's Avatar
P0171
I know there are hundreds of threads out there for this but nothing seemed to help me.
96 351 Windsor. Everything was fine until last night when I got done changing my coolant. I flushed it, replaced thermostat and filled it back up with 50/50. About 2 hours later is when I got the P0171 code. It seems to be running fine but I'd like to know where to try and start to fix it.
Old 10-24-2010 | 09:20 AM
jbrew's Avatar
Just clear it for now. If it comes back, then look for a problem. The system may have purged residual air within,- triggering the DTC.
Old 10-24-2010 | 09:31 AM
MTM Ford's Avatar
I cleared it with my Scan Gauge last night then it came back on this morning. I can try clearing it again.
Old 10-24-2010 | 09:32 AM
Look for vacuum leaks.
Old 10-24-2010 | 10:24 AM
MTM Ford's Avatar
I think I might have found the problem. The hose that's going from the air tube to the filler neck on the valve cover was off. I forgot to put it back on. When I got in the truck and checked my Scan Gauge it was showing P0171 and P0174. I cleared them and started the truck and drove it stopping a few places and doing an ignition cycle and nothing's come up so far.
Quick Reply: P0171
