Rough Idle for months and STILL no CEL!!
And if jbrew REALLY wants to argue over the internet, that's a little like competing in the special olympics. Even if you win, you're still retarded...
Here yuh go -
https://www.f150online.com/forums/v8...ram-07m08.html
That other guy can go blow,- his engine. I could care less at this point. If anyone has an issue such as this and with an 05 model, protect your wallet and have a qualified tech check your injectors. You can do this yourself as well, fairly easy. All you have to do is ask.
I know all about the problems with injectors on '05 models. That's not the question. The question is, does this mean that ALL injectors in ALL '05s will fail? All 7,512,000+ of them? Also, does a tech at one of the largest Ford dealerships in the Southeast not qualify as a "qualified tech"? That's what I've been trying to tell you. Maybe you missed it.
And on the checking the injectors yourself bit: Ok, I'll bite. How does one do this? I'll check them myself if it makes you happy.
Me having an 05 5.4 and been through an injector hydrolock situation I'd just have them change the injectors for peace of mind, but hindsight is 20/20.
The only warning I had was an extremely random hard start every now and then. Then one day an injector stuck open. No CEL, just was able to pull a code with my Edge.
