2001 Lightning with ticking noise and codes P0402 and P0171
Old 11-18-2010 | 06:40 AM
bowtiebender's Avatar
Exclamation 2001 Lightning with ticking noise and codes P0402 and P0171
I have a 2001 Ford Lightning SVT with a tick on driver side.It has codes p0171 and code P0402. It runs great with no performance problems, just an irratating tick at idle or park. I have changed plugs, coils, and EGR valve with no change.I don't believe it to be cam phasers from what i have seen in different forums. Maybe VCT solenoid? If anyone can help, it would be appreciated. Thanks.
Old 11-18-2010 | 06:49 AM
I have a 2001 Ford Lightning SVT, with a tick on drivers side. It runs great with no performance issues, just a tick that drives me crazy. It has codes p0171 and code p0402. I changed plugs, coils, and EGR valve, with no change in sound. It sounds like a exhaust leak. It only happens in park or idle, not when driving. Could it be a VCT solenoid, or maybe something else? Any help would be appreciated. Thanks guys.
Old 11-18-2010 | 12:46 PM
#1 you don't have a variable timing cam
#2 you have an obvious exhaust leak and it's dumping fuel in there trying to compensate for it and you're either washing downt he rings/ cylinder walls or fouling the new plugs
#3 stop driving it until you can afford to have the exhaust leak repaired
Old 11-18-2010 | 04:43 PM
You don't have VCT or phasers. Those are only on the 04+ 3 valve engines.
Are you sure the plugs are torqued properly? A loose plug will tick until it blows out of the head.
P0171 is a lean code and P0402 is an EGR code. You have something going on there. Your EGR valve may be sticking open a bit - whether it's the valve itself or something that's controlling it, you have to investigate that. Pull the vacuum line off the EGR valve at idle - any difference?
Old 11-19-2010 | 07:05 AM
how many threads does this guy need???
Old 11-19-2010 | 08:56 AM
Threads merged. One thread per subject, please.
Quick Reply: 2001 Lightning with ticking noise and codes P0402 and P0171
