The worst pick up in the world 4.6L
Old 07-09-2011, 08:22 AM
twinskrewd's Avatar
Oh for goodness sakes jbrew you have pushed yet another person over the edge. Here he has pulled the motor out of someone's car just to send you a pic.
Venxxxx good luck with it. Having the scan tool should help. Meanwhile I'd find the ecu to the sc'd motor in the pic and drop her *** in there and enjoy.
Old 07-09-2011, 08:51 AM
ONELOWF's Avatar
Ol' peanut brain strikes again.....
Old 07-09-2011, 07:35 PM
jbrew's Avatar
There's a chunk of history missing here. V knows. - I just haven't forgotten yet.
Old 07-09-2011, 11:57 PM
check your power and grounds on the injectors. IIRC PCM grounds it, you sure you have power?
Old 07-10-2011, 12:38 AM
venxxxxx's Avatar
I have powers on the left bank cylinders only. THe whole right bank fuel injectors is dead.
But there are sparks though.
All four cylinders on the right bank has sparks and fouled up pretty good on burning oil.
Old 07-11-2011, 04:40 PM
Need4racin's Avatar
No stored codes on the EEC?
Stop throwing parts at it.
Old 07-12-2011, 08:30 PM
tsmith1961's Avatar
I had a similar problem and it was the coil on the spark plug. I also changed the insulators that connect to the spark plugs. You probably checked that to start with. Good luck
Old 07-12-2011, 09:04 PM
jbrew's Avatar
Originally Posted by venxxxxx
Alright, I found the problem. It turns out the whole right bank didn't even get fuel. I attached a Noid light and none of them light up.The whole left side bank worked.
So now im guessing its the ECU itself which caused the problem
Yea but, how did you connect the noid ? To narrow down, you connect two ways. First thing and before you employ a noid, - start the vehicle and stethoscope each questionable injector. They all click loudly as they operate/ or open and close, -specially the Bosch. You can hear those while under the Stangs/Trucks if they're running headers (LT's) lol.
Quick Reply: The worst pick up in the world 4.6L
