$1950 and still not happy 2006 5.4L
Old 04-11-2012 | 01:17 PM
MGDfan's Avatar
Originally Posted by bankrpt
Or just let the truck sit over night and there won't be any pressure
Yep - I've found that after about an hour, it's good to go...
Maybe my injectors are leaking
MGD
Old 04-11-2012 | 01:23 PM
Originally Posted by bigemike
no, I am planning on doing both over the weekend and possibly the fuel filter this weekend too. Any tips for doing these jobs? maf is in the air intake tube (plastic housing) correct?
do you do the throttle body with the truck running?
I was thinking about a sea foam treatment.
Also I understand that the fuel filter is under pressure so what is the trick to doing it so I don't take a gasoline bath?
Seafoam is a bad idea.....use chevron techron instead.....
Old 04-11-2012 | 01:45 PM
sampson01's Avatar
Originally Posted by MGDfan
Explain, please. ^^^
I think the safer way, if it's necessary at all (and I've personally never had to do it, ever) is to trip the fuel pump cutoff behind the passenger side kick panel, start the truck and let it run until it dies.
MGD
wot will disable the fuel pump circuit. A lot easier than getting to the inertia switch and trying to knock the ball off that magnetic cup
Old 04-11-2012 | 01:47 PM
MGDfan's Avatar
Thanks! - I did not know that. Learn somethin' new every day
MGD
Old 04-11-2012 | 05:58 PM
Toyz's Avatar
Depress the shrader valve on the rail with a rag. If you can't see, use a lighter... J/K unless you don't want your eyebrows
Old 04-11-2012 | 10:27 PM
sampson01's Avatar
No problem. Perks from working for ford. Knowing random things Haha
Old 04-12-2012 | 02:00 AM
I don't think the 2006 has a Schrader valve.
You can also pull the fuel pump fuse and crank it over for about 15 seconds.
Old 04-14-2012 | 10:42 AM
ford4life.'s Avatar
thats how i crank my cars after an oil change
Old 04-14-2012 | 11:47 AM
sampson01's Avatar
Easiest way I'm telling ya haha
Quick Reply: $1950 and still not happy 2006 5.4L
