1987 fuel or ignition prob?
Old 10-11-1999 | 06:17 AM
Ferzees's Avatar
Question 1987 fuel or ignition prob?
Engine turns over but won't start. Seems like it's not getting fuel but there's 3/4 of a tank. Any ideas? It's a 6 cyl with dual tanks.
Old 10-11-1999 | 08:55 AM
Tina's Avatar
Exclamation
Have you checked your fuel pumps. I believe with those duel tanks, there are pumps in the tanks.
Old 10-11-1999 | 02:05 PM
Darin's Avatar
Post
Check for spark - if they are firing my guess would be fuel pump(s). My record with them is, 89 Bronco - replaced fuel pump / 88 Turbocoupe - replaced fuel pump / 90 LX 5.0 - replaced fuel pump. I also did heater cores in the bird and the stang. My opinion on earlier than 90 Fords is the factory fuel pumps and heater cores are garbage.
99 F150 XLT Silver 2WD S/C 4.2 5-speed, Superchip, Flowmaster muffler // Rear door switch guards - check them out at <A HREF="http://www.geocities.com/motorcity/show/5031
pud@iainc.net" TARGET=_blank>http://www.geocities.com/motorcity/show/5031
pud@iainc.net</A> -- Kennesaw GA
Old 10-11-1999 | 06:43 PM
Pastmaster's Avatar
Exclamation
Ferzees: Realize that there is 3 fuel tanks on your truck. Two Lower Pressure's in the tank and a high-velocity on the frame rail. I would have someone check pressure on the pump first.
Thanks!
1993 F-150 302/e4od/355 Limited slip. dual exhuast w/o mufflers,2 1/4" pipes with Echo Tips, headers, accel plugs/wires(8.6mm)/rotor/cap, hypertech powermodule, NEED INFO ON BLASTER COILS Alpine cd player and Pioneer speakers.(Front, need info on rears)
1989 F-150 XLT 4x4 302/aod true duals with turbo mufflers, 30X9.50" wild country tires, 3:55 gears w/LS(want after market LS for front)
Old 10-11-1999 | 06:48 PM
hmustang's Avatar
Post
May be the fuel pump I had a 87 Exp that done what your truck is doing and I even tried push starting it since it was a 5 speed had it towed to the dealership to have the fuel pump replaced the only time I ever had any trouble out of a ford.
Old 10-11-1999 | 08:57 PM
PKRWUD's Avatar
Lightbulb
Try and start it for a couple of seconds. Pull out a spark plug. If it's wet, you've got fuel, check for spark. If it's dry, try switching tanks and see if the problem goes away. It's unlikely that all your pumps would crap out at the same time. Did you check your roll over switch ???
Take care,
-Chris
'95 Eddie Bauer F-150 SC & '64 Falcon/Ranchero
Are you A.S.E. Certified ? If so, ask me about
iATN...the best tool you'll ever have ! ! And it's
free
Old 10-15-1999 | 06:55 PM
JERRY07's Avatar
Lightbulb
Hold on a minute!!! Sounds to me like the ignition module is bad. Have an 87F-150 and have replaced a couple in my times.
Take it out and have it tested.
Old 10-17-1999 | 01:44 AM
Jim Hartner's Avatar
Post
I had this problem on my 87 and it turned out to be the connection to the fuel cutoff inertia switch located on the firewall behind the brake petal.
A quick way of testing is to turn on the key and listen for the fuel pump to hum. If it doesn't hum, that might be the problem.
Good luck!
Quick Reply: 1987 fuel or ignition prob?
