1995 f150 wont start
Old 10-28-2012 | 04:10 PM
FordNFl's Avatar
5.0 e4od 207,xxx started the truck yesterday it ran for about 5 seconds sputtered, and died. It will not start back up .good spark, sprayed some either in the intake still nothing. Trouble codes read 111 system pass. Im stumped guys. All help is appreciated.
Old 10-28-2012 | 11:42 PM
K.R.newbie's Avatar
Makes no sense that you say you have good spark,,, but when you spray either you get nothing. If you spray ether and nothing means no spark. Might want to check fuel pressure. Also check spark again.
Old 10-29-2012 | 08:32 AM
FordNFl's Avatar
I will check spark again. I will also check it with a timing light. Im borrowing a fuel pressure gauge and do all of this when I get home from work. Thanks for your help so far I'll let you know the results.
Old 10-29-2012 | 08:30 PM
FordNFl's Avatar
Ok fuel pressure was at 38 book calls for 35-45. Wasnt able to get ahold of a timing light yet. Had my helper turn it over while I watched for spark. Looked week. Checked coil, it was out of range. Replaced it. Seems to try and start now but still wont. Found a leak in the roof that runs rain water into the area of the pcm. Wondering if this is my problem? borrowing anoid tester tommorow to make sure injectors are working and not stuck open. Any other ideas are apreciated, thanks.
Old 10-30-2012 | 02:00 PM
Pull the PCM, look for moisture and corrosion, smell it for evidence of burnt components.
Old 10-31-2012 | 10:44 PM
K.R.newbie's Avatar
Do like glc said. Might want to look for a junk yard pcm to try an use to see if that pcm is bad.
Old 11-05-2012 | 05:57 AM
FordNFl's Avatar
I got it runnning. Had water in the gas tank. Ive posted that I got it running but I dont see that post now... Anyways thanks everyone for the help.
Quick Reply: 1995 f150 wont start
