04 STX 4x4 Wont Start, NO Crank!!!!
yeah the starter is getting 12.26 V at the starter terminal, and getting juice from the crank trigger to the solenoid switch. the starter gives a single click. so it seems like its getting power. everything looks as it should. no obviously broken wires, little to no corrosion. my guess is the starter solenoid isnt fully engaging or the bendix drive is stuck or starter motor done. i tried the hammer trick as well, no luck. i ended up ording a a new starter for $55 shipped.
when you say jumping, you mean touch the 2 terminals of solonoid together with a screwdriver right????? i will give that a try and post back.
thanks for the post guys!!!!
i cant believe those starters are so cheap. 55 shipped. apparently it fits on the all 4.6, 5.4, 6.8, 6.2 and new 5.0. way to go FORD!!!
Follow Up------------->
arnt the the solenoid and starter one piece now.
it twas the starter. the $55 ebay special imo actually had a better design then the stocker. it had a cover over the Bendix drive and the ground strap from solenoid to starter was insulated. i think that was the problem, the ground strap fell apart on the old one.
now only time will tell.
