Another blown spark plug question(s)
Hey all… I tend to be more a reader vice a poster and I have been doing a lot of reading about spark plugs as of late. Seeing as how I just bought this (used high mileage) truck I plan on doing routine maintenance so I have a baseline going forward. I got the Haynes repair manual and went to the spark plug section. In that section it stated up front the TSB that is for 04-08 F150 (broken plugs) and that I should not perform this service. But after going down numerous rabbit holes I concluded that I have no idea why this was even mentioned in this repair manual (1997-2003).
Anyways, I had no idea about the blown spark plug issue until I went down these rabbit holes and now I have some questions that after numerous hours of digging I can’t seem to find the answers to. Hopefully some of you all can provide answers to them.
1. Is there a way I can tell if this truck has ever experienced the blown plug problem? If not and if it has experienced this problem, I assume I can still torque to the suggest 28 ft/lbs for the spark plugs.
2. On the blown out spark plug website under FAQ’s, number 49 states “In late 2003 the SOHC 2 valve type engines were upgraded to a 8-10 thread spark plug design.” I do not doubt what is being stated; however, I can’t find anything outside this website that confirms stated clam. If this is true, what month/year did this production change occur and where can I find the source?
If answers to these questions are already out there, I apologize upfront for creating a duplicate thread.
Thanks in advance for the assistance!
R,
Chris
2003 5.4L King Ranch 4x4
R,
Chris
R,
Chris
R,
Chris
as to #1....
if it has been done correctly it should be very hard to tell if there has been a "insert" in there to correct a past issue. other wise, one could maybe see a slight ring around the threads. Probably more noticeable on the piston side of the head.
as to #2 ...
I thought it was later in 03' that the "thicker threads" came down the line.
but I can't locate confirming info....perhaps a call to a the dealership could clear it up. If you're try to see if your truck has been equipt with the thicker threads....you will prolly need you vin # and build date.
or, but still not definitive note post # 22 in the following link >>>
https://www.f150online.com/forums/19...percrew-2.html
Enriched,
Thanks for the reply. Based on what you wrote for number one, leads me to believe if there was no issue (yet) and/or if it was repaired correctly a torque of 28 ft/lbs will not cause any issues.
I will check my build date tonight and I may give the dealer a call.
Thanks again for the reply.
