P0351 ???
Old 11-19-2012 | 04:50 PM
duckduke's Avatar
P0351 ???
5.4L V8 - 2006 F150
Changed plugs about 2000-3000 miles ago. No problem til this weekend. I noticed the CEL on.
I had the code(s) read at Oreily's today .... P0351 (COP or wiring at #1 cop/plug)
I noticed a rough idle at one point today (which is why I stopped and had the codes read) .... this is the only thing I've noticed other than CEL.
I've read all over on here and found that a number of different things could cause this code.
I plan on pulling the COP & wiring tonight and looking for any problem(s) before I start replacing anything.
Any suggestions would be apprecitated.
Old 11-19-2012 | 06:33 PM
Most likely the COP itself.
Did you change the boots when you changed the plugs? Did you use dielectric grease?
Old 11-19-2012 | 07:38 PM
duckduke's Avatar
no new boots
no dielectric grease
Old 11-19-2012 | 07:39 PM
Boots are optional unless they are dried out or you are not using OEM Motorcraft replacement plugs, but dielectric grease is required. I would pull all the cops and apply it.
Old 11-22-2012 | 05:23 PM
duckduke's Avatar
Found my problem I think........
-Pulled the bolt on COP #1
-Grabbed the plug to disconnect.... it pulled right off
The lock clip on the plug broke when I was diconnecting during the plug change. Apparently with changing temps, road vibrations, etc it can loosen.
That's where my problem it. Don't know how easy that piece of wire/plug is to replace but I need to do something to secure it.
Anyway ....... found the problem.
Old 11-23-2012 | 11:39 AM
For now, try a zip tie.
Quick Reply: P0351 ???
