No Oil Pressure at Cold Startup
2001 F150 4.6 So... If it's cold out (below freezing) I have no oil pressure at idle, gage shows pressure if I rev to above 1500 RPM. If I let it go back to idle it shows no oil pressure again. If I hold it at higher RPM it will start showing oil pressure at idle after a minute or so. Then no problems the rest of the day. It just started doing this in the last couple days, just as it started getting cold here.
Oil is not low & I just changed it a couple weeks ago, no sign of water in the oil.
Ideas?
Ideas?
