Flywheel grinding
Flywheel grinding
Hey all, I've got a 2000 f150 with the 5.4l v8, I blew a head gasket and pulled the motor to fix it, I replaced the flywheel with a new one, I droppe the engine back in and it starts, but the flywheel grinds as the engine spins. When I turn it over by hand the flywheel has one spot where it "sticks" which I assume is where the grinding is coming from, but it's not the starter or anywhere along the bottom of the bellhousing where it rubs, I backed the truck up an it drove fine but with the grinding noise still, however when puttin it in drive it doesn't seam like its going forward right. The side of the flywheel towards the transmission has scrapes on it from grinding and the side of the flywheel towards the engine is fine, anyone have a clue what it could be!?u
Flex plate? Auto trans? Auto trans does not have a flywheel, but a flex plate. Why did you change the old one out? Did it bolt to the TQ converter without problems? Are you sure it is even bolted to the Torque Converter.....? That is the trickiest part installing the engine back to the trans
