f150 stalls after water in gas
Old 12-22-2012 | 03:53 PM
Brian McCabe's Avatar
I have a 2004 F-150 with approximately 90,000 miles on the odometer. It has been properly maintained.
In the wake of Hurricane Sandy, when gas was scarce, I filled up with a mix of gas and water. The result was engine shut-down. The fuel pump was replaced and the engine seemed to run ok until it warmed up, at which point the rpms flipped back and forth between 600 and 1200. I ran a couple of tanks of 93 gas through the engine to clean out the injectors, but the problem persisted. Gas tank additives like Drygas did nothing to fix the problem nor did chemical cleaning of the injectors. The engine light is lit and the error code indicates that the mixture is too lean.
After a couple of weeks things got worse with the engine stalling at low rpms requiring me to take the truck out of gear at every stop while feeding gas to the engine to keep the rpms up. That led to replacing the idle valve but the problem persists. The truck is virtually unusable as it is. Also, there was no problem before water got in the gas. Ideas please. I’m out of business without my truck.
Old 12-22-2012 | 08:31 PM
JCR 56's Avatar
Check fuel pump driver module for corrosion,located on cross member near spare tire.
Old 12-22-2012 | 10:06 PM
c1t1d1's Avatar
i assume the fuel filter was changes when pump was, have you tried putting in a gas treatment to get ride of water in tank and lines and all?
Old 12-23-2012 | 10:14 AM
Thanks for the suggestion. I'll look into it and post the results.
Old 12-23-2012 | 03:35 PM
04f150owner's Avatar
i'm assuming you have the new body style 04? lower the spare and check the fuel pump driver module for corriosion, if haven't done so change the fuel filter. if all that is good you may need a set of fuel injectors.
Quick Reply: f150 stalls after water in gas
