Poor low-end on 99 5.4
Old 04-17-2014 | 09:44 PM
white elephant's Avatar
I dropped a 99 5.4 into my 98 f-150. I added long tubes, Denso plugs per Mike Troyer's recommendations with Accel wires from Mike with the stock 4.6 coils. I had a local guy tune the engine for 93 and 87. It ran like a scalded dog from 2000 rpm up, but was poor under 2k. I thought the original tuner might have missed something so I had Mike also make a 93 and 87 tune. The 87 tune pings like hell and is being reevaluated. The 93 tune runs a little better than the other 93 tune I had, but the bottom end is still about the same.
My low end power issues are very similar to what this thread was about:
https://www.f150online.com/forums/v8...ower-gone.html
Unfortunately the owner never posted any improvements.
My 4.6 was 100% perfect mechanically when I pulled it, but it too was down on low-end power. The idle was/is at times a little rough on the 4.6 and now on the 5.4, but is not noticeable to the average joe. I have no codes. My coils have 89k miles. When coils go bad, is it across the entire RPM range or one specific area?
Will dirty injectors cause low-end issues?
I pulled the IAC and cleaned it. It wasn't very dirty, but I don't know if it was functioning correctly.
I cleaned the MAF.
I have not checked/cleaned the EGR, dpfe or EVR.
I did have a broken vac line that I fixed. I will tape the joints to ensure no small leaks are present.
The 5.4 engine has 100k. It's no spring chicken, but I would think if 2k rpm up is good, 2k down would be good too.
HEEELLLLPPP! Thanks!
Old 04-17-2014 | 10:31 PM
Roadie's Avatar
The headers usually decrease low end torque and help it in the higher rpm.
Old 04-17-2014 | 10:55 PM
jethat's Avatar
whats your gear? That might be the answer..
Old 04-18-2014 | 12:18 AM
Toyz's Avatar
How many miles on your 02s?
some live date would certainly help
Old 04-18-2014 | 08:29 AM
O2's are original so 89k.
I'm strongly thinking spark or fuel issue, but I don't have experience with coils crapping out or injectors with excessive funk.
I have seen a few other posts of this issue at about the same mileage, but no one has posted results other than one guy who cleaned his IAC.
Old 04-26-2014 | 12:13 AM
weak cops
lack of maintenance
Poor fuel
torque converter
Old 04-27-2014 | 09:19 AM
-Does not have cops.
-I almost always run BP from high traffic stations.
-I consulted Hughes on the converter before i made the swap.
-What maintenance issue would cause loss of low end only?
Old 04-27-2014 | 03:14 PM
thelariat02's Avatar
...missed the point you swapped it
Old 04-28-2014 | 01:17 AM
might be tune related...
Quick Reply: Poor low-end on 99 5.4
