2009 F150 P0442, wont start
Old 06-28-2014 | 04:53 PM
RAlaniz's Avatar
man,
i'm struggling with where to begin.
i have 2009 F150 5.4L, 163,000 miles with fuel cap-less system
Truck won't start. Now showing (3) P0442 messages.
Evaporative Emission System Leak Detected.
1. Confirmed!
2. Pending!!
3. Permanent!!!
help, what do you recommend?
Old 06-28-2014 | 11:52 PM
EsJayEs's Avatar
That isn't a code I would associate with a no-start condition. So it may not be related.
Start with the basics of troubleshooting - fuel and spark.
Any other piece of this puzzle missing? Anything recently tinkered with that may be related?
Old 06-30-2014 | 09:39 AM
RAlaniz's Avatar
thank you for your reply.
I haven't done any tinkering lately on this vehicle.
the truck Will start with starting fluid but will not continue to run.
how should i trouble shoot the fuel system?
does the fuel system shut-down with a failed Canister Vent Valve Solenoid?
how can i get a map-drawing of the EVAP sytem?
how can i get a map-drawing of the fuel system?
Old 06-30-2014 | 08:56 PM
projectSHO89's Avatar
That fault code has nothing to do with a "no-start" condition.
You need to start with the really basic stuff:
1. Is the Theft light flashing (shuts down fuel delivery)?
2. Do you have fuel pressure (use a gauge)?
3. Have you tried cracking the throttle (allows air into the system)?
Old 07-01-2014 | 12:28 AM
EsJayEs's Avatar
Telltale signs of a failed fuel pump (generally). However there are other things that control it. When you turn the key to the run position, you should hear the fuel pump cycle on for about two seconds. If you don't hear that, you'll need to verify that power is going to the fuel pump. If voltage is present but the fuel pump doesn't cycle momentarily when the key is turned to the run position, replace it. If it is receiving power, report back for further details.
Old 07-01-2014 | 05:56 PM
jethat's Avatar
fuel pressure check. You'll need a decent scan tool to do it because they eliminated the fuel rail pressure check zerk.
Quick Reply: 2009 F150 P0442, wont start
