O6 f150 5.43valve
my 5.4 took a dump in the interstate at normal highway speeds, new Mobil 1 oil and filter, but my oil pressure dropped suddenly and sounded like the chains were rattling so bad.
the dealership told me, there's no fix once it gets to that point, which surprised my, I work on Harley motors, I know the twin cam setup is similar with the chain drive, when the tenioners go, the can be replaced and go on, so who to believe?
I had no choice and was lucky the dealership went in half for the re manufactured motor -
It's piece of mind for me, knowing I have a, what I think is a better than new motor, all the updates for that motor, and a 3 year unlimited miles warranty
Last edited by cvitullo; 01-24-2017 at 11:05 AM. Reason: warranty info was incorrect
Phaser issues can definitely be long-term fixed by following a few simple rules. Foremost - use ONLY Motorcraft Phasers, NEVER cheap aftermarket knockoffs. Phasers themselves are seldom the 'root' problem, so when you go in don't cheapskate the job - replace everything while there, (including rollers/followers if mileage is up there > 150-200k) and use ONLY quality parts. Do-it-yourself should hold parts cost less than $2,500 tops - even with misc. stuff. definitely less than engine swap.
Deciding to go for it is more nerve racking than doing the job. If you stay ahead of the major failure (chain jumping a tooth or serious DTC's) and just have diesel noise, startup rattle and rough idle, you can make a very informed decision by adding an aftermarket Oil Pressure gauge and run a good wet and dry compression test on all cyls. If lower end, rings and valves are OK, timing job should give you plenty more serviceable miles.
222k puts me 10K+ into my '04 5.4L timing job, burns practically NO oil (~1qt/2500 mi), and I believe it pulls/runs/performs as well as it did right after breakin. Fuel mileage is respectable (13.5ish all around city/urban/hwy).
Good luck
Good luck
When doing a job of this magnitude, one should always check out all the elements associated.
Oil pressure is what drives the VCT function. It should be tested.
Cam chain tensioners, and it's tension-er piston seals checked or replaced.
The VCT gears replacement and timing procedure fully understood.
For the expense and labor of the job there should be nothing left to cause an early future failure from lack of attention that results in wasting the effort and expense..
The oil passes up through the block at the rear of the head on the passenger side through a filter screen, through the camshaft core to the front sensor.
The driver side oil comes up in the front to the phaser and through the cam to the rear.
The sensor, under control from the computer, gates oil and volume into the VCT gear changing it's phase timing with the crank.
Very often the phraser failure is due to poor oil change intervals.
At this point there could be some serious wear to the cam journals oil pump and other parts that cause lower oil pressure and leading to VCT system issues.
It's not a job to take lightly.
There is always an element of doubt that something has been left unseen , so some luck is in order with every job.
Good luck.
Good luck.
