06 f150 - just purchased questions
hey guys, I just picked up an 06 f150 with 100k on it. (prev 96 f250 7.5L).
i heard quite a bit of problems with the 3v motor but i got it for dirt cheap so i figured what the hell.
No maintenance records on carfax so im going to assume it wasnt maintained very well.
first thing i did was drop in some mobil 1 full synthetic 5-30 and a new air filter. (old oil definitely seemed a bit sludgy)
been doing some research but i would like to know what else i can do to ensure i wont run into many issues in the future
engine runs good, no ticking or signs of phaser problems ect. starts fine, however when i give it a rev it will come down to a rough idle for a few seconds and then correct itself.
Also the power steering seems a bit stiff at stop lights. idle rpm is around 550. fluid level is fine.
I want to do an oil pressure test, replace fuel filter, replace the plugs, check vct solenoid screen ect, maybe seafoam?
any other things i should look into or do?
Thanks in advance
Thanks in advance
