Codes 171, 174 and 353
Old 12-20-2020 | 02:40 AM
Rond7485's Avatar
2002 ford f150 4.6L Codes 174, 171 and 353. I have not found any vacuume leaks, the maf is good cleaned injectors changed pluga coils are good. I get a s.t.f.t. reading of -9,7% on both banks and 29% on both banks for the l.t.f.t. I can't figure this out. Full pressure is good. I don't know where to go from here. I thought a burnt valve but no smoke at all from the exhaust. The truck runs very rough. Any advice
Old 12-20-2020 | 09:58 AM
What kind of plugs are you running? I recommend Motorcraft.
Old 12-20-2020 | 10:21 AM
Roadie's Avatar
It may be worth it to pay a mechanic to do a smoke test. If you have a shop vacuum, you can reverse the flow and blow up the tail pipe and use soapy water spray to find the leak. Chris Fix has a video on this. Or you can use an unlit propane torch to find a leak. There are lots of utube videos that show how to find a vacuum leak.
Old 12-20-2020 | 11:38 AM
Rond7485's Avatar
I am using autolite plugs .
Old 12-20-2020 | 11:43 AM
Rond7485's Avatar
I've done the propane test several times. Not only did I not find any, it would have to be a pretty good sized leak to make it run as rough as it is. I will try the reversed shop vac thing right now though.
Old 12-20-2020 | 12:21 PM
No good. Known issues in Triton engines.
Old 12-20-2020 | 12:22 PM
You may want to do a compression test.
Old 12-20-2020 | 12:25 PM
Roadie's Avatar
There is a South Main Auto Repair video about smoke testing an F150 and the leak was a rusty brake booster!!!!
Old 12-20-2020 | 01:54 PM
Rond7485's Avatar
I've checked the converters they are fine. I've done the propane test very slowly and methodically and came up with nothing. I'm thinking maybe a valve
Rond7485's Avatar
What should the fule pressure be?
Old 12-20-2020 | 01:57 PM
Rond7485's Avatar
My maf is jumping from mid 80s up to 115. It's all over the place at an idle.is this normal?
Old 12-20-2020 | 02:21 PM
Rond7485's Avatar
I disconnected a vacuum line and shot propane directly into it and it didn't even phase it. s.t.f.t. didn't change a bit.
Old 12-20-2020 | 02:23 PM
Rond7485's Avatar
I went and bought a compression test kit ans none of the fittings would screw into the head.
Old 12-20-2020 | 02:42 PM
I highly recommend changing your plugs from Autolight to Motorcraft before going further.
Make sure they are gapped accordingly.
Old 12-20-2020 | 03:46 PM
Roadie's Avatar
Fuel pressure on my truck runs around 30psig
Quick Reply: Codes 171, 174 and 353
