shuddering
Old 10-22-2001 | 03:35 AM
King James's Avatar
Originally posted by brianf150
My 99F150 xcab was doing something simular to this. It would shake at low RPM but, if I mashed on it the shake would go away. Turned out to be a bad distributer pack. Haven't had the same problem since. Now my starter relay seems to have gone bad. To start my truck I have to turn the key on and then take a screwdriver and short across it to get the dang thing to start. The strangest part is the radio died with it.
Check the fuses under the hood on the driver side.
Old 10-22-2001 | 05:49 AM
Mach1's Avatar
Footwart--I believe what happened to you was the lift kit changed the pinion angle the correct way and eliminated the shudder....
Here's what I have, its only in 2nd gear that the trans shudders, What's strange is when I get on the throttle and give it just a little more rev's it doesn't shudder...
I am thinking that either the pump supply's more pressure, which keeps it locked instead of slipping....or by giving it more throttle it slips more...
Its only in second gear going slow and accelerating slowly, does it do this...
OBTW---Matt you are a lot nicer here lately.....
You are much more pleasant to read now.....
Old 10-22-2001 | 07:07 AM
King James's Avatar
Disconnecting the MAF made the truck run like crap matt.
Quick Reply: shuddering
