fan shroud
Old 10-21-2001 | 02:12 PM
footwart's Avatar
fan shroud
I HAD A 3 INCH LIFT PUT ON MY TRUCK. I HAVENT DRIVEN IT UNTIL YESTERDAY. AFTER DRIVING FOR ABOUT AN HOUR THE TEMP GAUGE WENT TO RED AND THE OIL LIGHT CAME ON,PLUS CHECK ENGINE LIGHT. AFTER GETTING HOME I NOTICED THAT THE FAN WASNT TURNING. THEY HAD NOT REMOVED ENOUGH OF THE SHROUD WHEN THE TRUCK WAS RAISED. SINCE THE FAN WAS LOCKED UP ON THE SHROUD WILL THIS HAVE AN ADVERSE AFFECT ON IT. I DID REMOVE THE SHROUD AND SHAVE IT DOWN SO THAT THE FAN SPINS FREELY. EVERYTHING SEEMS OK BUT NEED OPINIONS. I WILL ALSO BE CALLING THE SHOP FOR A LITTLE HELL RAISING
Old 10-22-2001 | 12:40 AM
Matt90GT's Avatar
Body lift I assume? There are directions to trim and relocate the fan shroud with new mounting brackets in most all of the kits. sounds like someone missed a step
Quick Reply: fan shroud
