Fuel pump
Fuel pump
I have a 1990 F-150 inline 6 and it acts like it is not getting fuel, I check the fuel and noticed that i can not hear my fuel pump. Question, for this type of vehicle, is there a high pressure pump and if there is one, where is it.
[This message has been edited by wlee (edited 06-09-2000).]
My 89 has a booster pump in each tank and a main pump on the frame rail under drivers door. I believe that in 90 on they went to a pump in each tank and no external pumps. You can get a fuel pressure reading from the test port on the fuel rail next to injectors. Key on engine off around 35 Psi is close to normal.
2000 XLT Bright red, Flareside,extended cab,sport,5.4,bedrug,Extang tonneau.
