Can You Say Bolt On Performance..!
Old 11-18-2000 | 10:17 PM
TRITONTIMES's Avatar
Talking Can You Say Bolt On Performance..!
Well guys , I just installed my K&N F.I.P.K and my PowerAid TB spacer.Well let me just say what a differnce.A week earlier i installed the superchip and with these 3 put together the following changes i have incounterd are awesome. 200 rpm gain , 300miles to the tank aposed to a 260 (25 gal 5.4 L heavy foot) The tires will let loose like a beafed up Mustang at the light.The wistling sound is moderate and sounds kinda cool. Before the new intake and spacer when I just had the chip top speed was 106mph. Also gained by new intake and spacer was a Big Smile , next Headers , any ideas anyone and also what would happen if i took the cats off...?
Old 11-19-2000 | 02:58 PM
max mitchell's Avatar
Cool
Now that it breathes in better, this will work well if combined with an exhaust upgrade. Late model cats flow well and it is against Federal law (50-state) to remove them. They can be replaced after 5yr/50k. The biggest restriction in the exhaust is the OEM garbage can muffler (flows 200 cfms approx). A well engineered cat-back system can do alot for the price.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
Mobil 1, K&N oil filter, K&N F.I.P.K., Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s.
Old 11-19-2000 | 04:46 PM
black f150 offroad's Avatar
Post
yeah your check engine light will come on, eec v uses cat monitors wich is a good thing, u should take a look at emission levles with cats and without and u will see why it is a good thing that the govenment forces people to leave them on, eec v is more for emmision control than anything, eec v is emision management, eec iv was power train management, besides a cat does not rob as much power as u may think people give then a bad rap because they don't know what they do, just like the air pump, egr valve, etc
Old 11-19-2000 | 05:21 PM
TREADMARKS's Avatar
Post
Lose the cats, my cats sucked, all four of them. Now it sounds much better, revs quicker, and pulls a little harder. I can feel the difference even more at higher rpms.
I had high flow cats installed, and I am still using all four stock sensors. No check engine light. Only smiles.
good luck..
Drive it like ya stole it,
Terry Deaton
99 F150 XLT, 2WD, 4.6, S/C, S/B, Superchip, K&N FIPK, FMS 9mm, +4s, Nerfs, Leer Top, Cow Catcher W/Bright A$$ Lights, True Duals with hi flow cats, 275 Dunlops with 3.08 gears, fat swaybars, Steeda front and Hellwig rear, 3.5" Fabtech spindles with 2" blocks, B/E Performance Shift kit with B&M Cast Deep Pan, Steeda Billit Pedals.
Coming Soon: 4.10s and Auburn Diff, Eibach Front Coils and Add a Leafs, Underdrive Pullies and Kick A$$ Shocks.
96 SVT COBRA (almost stock)
98 AERO black w/lotsa chrome
Speed Kills, drive a Chevy and live forever.
http://www.geocities.com/terrydeaton.geo/index7.htm
