Do I have Limited Slip?
???? I've got limited slip and I don't get any "jerky" feeling or hopping around. If you want to use a "spin" method to check it, try in sand or lose dirt, or even a slick wet road but be careful if you decide to do it on a slick road.
I think on a slick wet road you'll know real quick if you have an open diff. With mine, LS just keeps me straight and solid on the ground.
Hey!
It's very inconvenient that search option is disabled...
BTW, any words on whether is will come back????
Here is the list (from different F-150 site) of codes on the driver side door under REAR section. Look what matches to yours....
F-150:
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
F-250:
27 – 3.31 Non-LS
26 – 3.73 Non-LS
Ranger:
84 – 3.45 Non-LS
86 – 3.73 Non-LS
87 – 4.10 Non-LS
89 – 4.56 Non-LS
F6 – 3.73 LS
F7 – 4.10 LS
92 – 3.08 Non-LS
R5 – 3.55 LS
91 – 3.27 Non-LS
96 – 3.73 Non-LS
R6 – 3.73 LS
F-150:
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
F-250:
27 – 3.31 Non-LS
26 – 3.73 Non-LS
Ranger:
84 – 3.45 Non-LS
86 – 3.73 Non-LS
87 – 4.10 Non-LS
89 – 4.56 Non-LS
F6 – 3.73 LS
F7 – 4.10 LS
92 – 3.08 Non-LS
R5 – 3.55 LS
91 – 3.27 Non-LS
96 – 3.73 Non-LS
R6 – 3.73 LS
With a truck that old, you guys are assuming alot..If it is original then that will work....If it has lots of miles or is second hand you dont know whats in there now.....
The ratio is easy to figure out as well...turn the tires until 1 full revolution is made on the driveshaft ..these numbers form the ratio...
