Need help with speedometer gear install
It's about as hard as sliding under the truck. There is only one bolt that holds it in. It's located on the driver side near the rear and has one plug in. Unbolt it, you can unplug it if you want, slide the clip off, slide the gear off, slide new gear on, replace clip, lube the oring with a little clean ATF and bolt it back up. 10 times cheaper and 10 times easier than fighting with a dealer to reprogram a 99 or newer truck, IMO. The newer you get the harder they mae it for the average Joe.
