Electric Fan
Old 12-23-2000 | 07:16 PM
boom's Avatar
Post Electric Fan
Looking for information on electric radiador fans.What to look for and what not to.Have 1997 F150 XLT with 20,000 miles.
BOOM
Old 12-23-2000 | 08:07 PM
JMTruck's Avatar
Post
Check with Neal. He's done this mod in his truck with two 16 inchers.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Superlift 3" lift blocks
Performance Lift Lips
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
Old 12-23-2000 | 08:43 PM
Neal's Avatar
Cool
HI!... BOOM : I'm running two DERALE "TORNADO" 16 inch electric fans, (119.95U.S) from SUMMIT RACING. They mount perfectly on the stock rad with only about a 1/4 inch of room to spare. The kit comes with all the needed hardware. It also comes with very high quality fuse holders and copper (not "ZIP" ties) fasteners to mount the fans to the rad. I also bought a PERMA COOL electric fan installation kit with thermal switch. ($39.95U.S) from SUMMIT RACING. This thermal switch is actually a electronic thermastat that activates the fan when it hits the pre-set temp. I am running one fan off of the thermal switch and the other is wired to a lighted toggle switch mounted into my engine temp guages, guage pod. I very rarely have to activate the 2ND fan. In the SUMMER my temps stay pretty stable at about 185 - 195 degrees. I am very pleased with this set-up. I have even towed up to 8,000LBS with these fans with NO overheating. I also noticed after the installation that the engine seems to rev up faster in 1ST gear now. I also picked up about 4 mph on top speed. Hope this helps you out and if you have any questions, just ask.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old 12-25-2000 | 07:07 PM
Neal's Avatar
Cool
HI!... BOOM : I really don't know if it helped my gas milage or not. I'm not really interested in gas milage. All I know is that I have to travel 240KMs to my close's CANADIAN dragstrip and when I leave my house with a FULL tank of gas, I get there and have only used about a 1/4 tank. The time I get back (another (240KMs) I have about a little less than 1/2 a tank left. So I figure 480KMs on roughly a 1/2 a tank of gas is pretty good for all my mods and my 4.10 gears.
Old 12-25-2000 | 07:18 PM
Neal's Avatar
Cool
HI!... CRASH : YES, the fans mount side by side. They are $119.95(U.S) EACH. I would'nt say the fans are worth 20H.P though. Mabey 10-12H.P at the MOST. Remember that the fans ar'nt actually making H.P. They are just giving you back the H.P that the clutch fan assembly is stealing from the engine. You could get the same H.P by just simply removing the clutch fan, but then your truck would overheat in a matter of miles. I wish I could of gone with a supercharger 1ST, but because I live in CANADA that means I have to save up $6000.00(CAN) just to buy one. I'm having more fun right now trying to go fast NATURALLY ASPERATED!lol! My goal this year is to go 13.9 N/A. WE'LL SEE!lol!
Old 12-26-2000 | 01:03 AM
Neal's Avatar
Cool
HI!... CRASH : Yes I know people in the states. That's not the problem though. The problem is when you try to come across the CANADA/U.S border. They will search your vehicle and if they find something that you did'nt declare then you might as well KISS your vehicle good-bye and plan on doing some jail time! If I did declare a SUPERCHARGER, the CANADIAN customs will take the U.S price of it, convert it to CANADIAN currency and then charge our 15% sales tax on top of that! That's why it's so expensive to get anything from the states into CANADA. I wish I knew someone in the states that I could actually install the SUPERCHARGER in their garage. Then I could just drive across with it on the truck. OH WELL, that's what it is to be CANADIAN, I guess.LOL!
Old 12-26-2000 | 01:33 AM
boom's Avatar
Post
Thank's for the reply Neal.
I was just wondering if it helped your gas milage any? About the best that I can do is 12.5 on a good week.
I have the 4.6L.
Thank's again for your help.
Boom
