white junk on oil filler cap
Old 12-27-2000 | 05:59 PM
hd99's Avatar
Question white junk on oil filler cap
I changed my oil ('97 F150 4.6L) this weekend after the usual 3000 miles and noticed kind of a white slime on the bottom of the oil filler cap and the inside of the filler tube. It wiped right off though, not sticky at all. Any idea what it might be? Please don't say antifreeze. I thought it might be foam from the oil on top? The oil looked good in the pan, no streaks or odd colors. I don't have a black light to look for antifreeze though. By the way, I use Quaker 5W30. Thanks.
Old 12-27-2000 | 06:07 PM
jgorka's Avatar
Post
While you cannot categorically rule out antifreeze -- it is more likely that it is water condensate.
In winter months, it is normal for areas of the engine that don't get hot to condense water -- which can often resemble a whipped-up version of Vasoline Jelly.
On engines where the oil filler cap is mounted on a raised tube which is in line with radiator fan air -- rust often forms on the metal of the oil cap.
Running the truck at highway speeds long enough to heat the oil to something above 212 deg F -- it is the usual 'fix' for this type of problem -- and is one of the reasons why winter driving is often considered 'severe'.
Wipe the slime -- change the oil -- drive it -- and rest easy.
Y2K™ 7700 4x4
Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Old 12-27-2000 | 07:33 PM
jaymz's Avatar
Post
It's condensation. Completely normal, especially in climates where temps vary widely.
Wipe it off; drive.
Old 12-27-2000 | 11:05 PM
gopher's Avatar
Cool
Normal! Just do like crash! says and you'll be just fine!
1997 F150 XLT, Flareside , Moonlight Blue, 4x2, SC, Auto, 4.6L, 3:08, Cargo Cover by Century, Penda bed liner, Blue Oval reciever hitch plug, Driver Design bug deflector, Monroe Reflex Shocks, 235/70/16 Firestone Wilderness AT's, sliding rear window, captain's chairs, Valvoline Durablend Oil, Purolator Pure One Oil Filter, and 114,000 miles and counting!
Old 12-28-2000 | 10:18 AM
hd99's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by jgorka:
</font>
Thanks for the information, I was hoping it was something like that. When I saw it the truck had only ran about 20 minutes and it was about 10 degrees out.
Quick Reply: white junk on oil filler cap
