leaking brake fluid tank
I have a 1999 extended cab. The brake fluid tank is leaking. It stays wet on top of the tank, and around the bottom of the cap. I have taken it in and received a new cap. I took it in again and was told there was nothing wrong.
I just got back from the service department today and was told that it is normal for the new plastic tanks to leak.
Does anybody know if it normal? I think it stinks! It doesn't seem like it should be normal to have a brake fluid resevoir that leaks.
Thanks for any advice.
Hey TKN:
Welcome to the boards. Now that you mention it, the cap on mine always seems to be a little damp, too...........
Click on any pic below for a closer look:
<A HREF="http://www.zing.com/picture/p8bbc38a6b8da7299901c07d2740149c5/ffaf352e.jpg.orig.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p18dfc566f482837068e8ff7599500eac/ffaf3443.jpg.orig.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/pbe7cf6fd92bd647780a60a53170b215f/ffaf34dc.jpg.orig.jpg" TARGET=_blank> </A>
2000 XLT Sport, Flareside, 2WD, SuperCab, 5.4L. Factory options: 3.55 LS, Class III tow, Dark graphite captains chairs & console w/CD changer, Remote entry , and Slider.
Mod Highlights: Window tint, light covers, Linex bedliner, ARE LSII lid, Flowmaster cat-back exhaust kit, and a Classic Design Concepts front bumper cover.
Wish list: K&N FIPK, Belltech 3/4 drop, rear sway bar, and a SuperChip.
For details, go to: <A HREF="http://home.columbus.rr.com/selva1/f150.html" TARGET=_blank> </A>
[This message has been edited by selva1 (edited 08-01-2000).]
I had this since new also. The dealer said "Someone just spilled some." I tried smoothing the brake reservoir, buying a new cap, and lowering the level; didn't help. When the cap is closed, you can grab it and move it slightly. This may sound strange, but I put a plastic home made shim between the inner cap top and the rubber seal. The cap is tighter and the leak is 90% better. I'm glad you guys mentioned this, because this has pissed me off from the beginning. I've never had a car with such a stupid brake cap problem. If anyone else has found a solution, PLEASE HELP US!!!
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
I went back to the location where I bought the truck. Had the service mgr take a look. They presured up the brake system for 15 minutes and it was leaking at the cap. Put a new one on and prssured again for 15 minutes and no leak.
That's the second new cap I've had. I'll see how long this one lasts.
TKN
TKN
