1997...4W ABS?
The easiest way to tell if you have 4WABS is to pop the hood and look under the air intake system between the engine and the driver's fender well. Ther will be a box with alot of brake lines going to it. If you have that, you have 4WABS. If not you have rear wheel only.
Red '97 F-150 SC 4x4 off-road, 16" rims instead of factory 17"'s(borrowed from old '97 reg cab), BFG 265/75 16 all terrain T/A, K&N filter with modified air box, Flowmaster 40 with duals out back, Expedition center console, 3" rear seat lift, after market stereo seen at HTTP://members.sounddomain.com/red97,
Chris, rear ABS is very important on P/U trucks. If the rear locks up in a panic stop, it can swing around in front of you...kind of like a trailer jacknifing. I saw it happen on a Consumer Reports show. Yes, most of your braking is in the front but if you had a choice of axles, ABS would be more effective on the rear.
