Wanted, Lightning wheels !
I am looking for the older lightning wheels for my 2003 f150 fxa 4wd. I like the ones that came on the 99's. I have been told they will work with my 4wd.
Looking for either wheels alone or wheels & tires.
If you are interested you can have my 2003 brand new tires and wheels.
I live in Vancouver, BC but shipping can be to Point Roberts WA 98281 as well.
this is what I am looking for:
https://www.f150online.com/galleries...-106-26589.jpg
it might be hard. The 99-00 type used 12mm lug nuts and the 01-03 style's use 14mm lug nuts. You haveing a 2003, you have 14mm lug nuts. So unless you can order some with larger holes, you will have to swap lug's or bring out the trusty drill.
I think this is correct, might check with others to make shure.
on
Phil got it correct, but one more twist.
The build date of before 29-NOV-99 has 12 mm lugs, 29-NOV-99 and later have 14 mm studs.
Don't ask me how you can tell which 00 wheel has what on it.
This is straight from the Ford Racing catalog page 81.
Don't forget you Lightning wheel, wheel stops Ford racing part number : M-1010-L, nop matter what year you get.
on
Re: Wanted, Lightning wheels !
Originally posted by Robert B. Chuhran
jimwww:
Yho, how did you get a picture of my " Lightning " ??? This was
in Virginia Beach, Va. I'm sure, right ?
jimwww:
Did you make one here, b/c there are a whole bunch of pictures of the Red L in the same back drop, along with :
https://www.f150online.com/galleries...-106-26661.jpg
and
https://www.f150online.com/galleries...92-106-605.jpg
I would hope that this is your gallery here, else someone that was there took the pictures and posted them in a gallery on this site.
If you look at the Gallery ID you have it would have the number 92-106* in it. do a search on this URL for that starting number and you can find all your pictures lumped into one area ( along with all the other pictures )
https://www.f150online.com/galleries/images/
Mine is 1408-1916* for the list of my pictures in the above URL.
