Tire pressure with 20's?
well in my lightning the stock PSI is 32 with 295/45/18 tires i am getting 20's with 295/40/20 and due to the lower side wall i have been advised to bring up the pressure a few notches like around 36 to 40 PSI cold so i guess you could get away with the same 32 psi but i would say go more like 33 to 34 rear and 35-36 front< if your two wheel drive for 4x4 i dont know
Your best bet for road use is to follow the door sticker. The tires list the max pressure that can be run. Running too little pressure could allow too much patch on the road and the risk for roll over increases. (The tires will out perform the truck's capabilities). I've watched one roll over at a driving track. The tires did what they were built to do, stick to the road. Stock tires would have slid and kept the truck upright.
