Help! 35x12.50x17 with 4" lift
They will fit. The most you would have to do is either crank the torsion bars up a little and/or do a little trimming on the valance. I fit those tires with a 3" lift and cranking the torsion bars and doing a little trimming to keep them from rubing offroad. This is the reason you NEVER listen to people like that in tire stores on fitment. Most of the time they don't know a tire from their ***.
It could also depend on what backspacing your wheels have whether you get rub or not. I just got some 315/70/17 BFGs that I'll put on after I get a 4" Rancho and 2" body lift. I think that lift with 9.5" wide wheels with 4.5" backspacing should fit just fine without any rubbing. Hopefully, I'll find out soon -
Mike
Mike
Originally posted by powerstroke73
He won't HAVE to. There is alot of variablility in the production of these trucks. Just cause one person does doesn't mean another one with the same setup will have to.
I have talked to many guys who are running the 4" setup with 35's on wide wheels. I can only recall one maybe two of the guys didn't have to trim or crank their torsion bars.
I trimmed the front valence and cranked the bars to get the most clearance I could with the 4" setup.
Ant
