7 lugs on my truck????????
Hvy Dty?
Originally the "Light Duty" F250s had the "7 lug" wheels. I guess that when Ford came up with the "7700GVW" package for the F150, it included the 7 lug wheels (higher weight rating). Good luck with the truck, it ought to really "haul"! Should have said it first, but WELCOME to the site!
In 2000, Ford did away with the F250 light duty and created the F150 7700lb GVWR package (Gross Vehicle Weight Rating). It is essentially the same thing as the F250 light duty. It has larger brakes, the 4R100 transmission, a heavier frame, a 3.73 rear end, and as you have noticed - 7 lugs wheels instead of 5.
PS - Welcome to the boards!
