ABS Light
Old 08-25-2004, 09:26 PM
cdawley's Avatar
I ordered the sensor and got it in the mail. I measured the resistance on the part before I put it in. I got about 1k-ohm out of it. I figured it was within specs since the sensor is supposed to have between 800ohm-3.5kohm. I put the sensor into the truck and drove it around the block. The ABS light came back on. I then proceeded to check the OR/BK wire and didn't get any flashes out of the ABS light when I turned on the switch. I also have a Ford Service Manual CD for my truck and it said if I don't have any flashes, it could be my Anti-Lock Brake Control Module. The CD says that if I measure the voltage between the LB/PK and GND and the voltage is less than 10V, that I should repair the 601 Circuit. What is the 601 Circuit? It also says if the voltage is greater than 10V to replace the Anti-Lock Control Module. When I measure the voltage between the LB/PK and GND, I get around 2.0V. Is this an ok reading or do I need to repair the circuit?
  #47
Old 08-30-2004, 08:22 PM
Hazzard's Avatar
ABS light OFF!
Man, you guys rock!
My ABS light has been on for about 20,000+ now. It started off intermittent, but eventually stayed on all the time.
I read this thread the other day and thought I'd give the rear differential sensor a shot. Stopped by my local Ford dealer at lunch today and picked up a new one for $22.88. Just popped it in when I got home, and the problem is gone! The connector was a pain in the neck to get back on, but I got the job done.
The ABS light is now OFF. Thanks guys!!!
1999 F-150 XLT 2wd
85,000 miles
  #48
Old 08-31-2004, 09:22 PM
sdtsdt's Avatar
There is a rubber gasket/sealer on the plug/connector end of the sensor. The original one may stick to the connector when you pull the plug...then when you try to put the connector on the new sensor, it doesn't want to go one because the new sensor has already has a gasket on it... That is probably why Hazzard had a hard time putting the connector back on ...
I replaced a sensor a couple of weeks ago and still get a intermittent ABS light on and off... I am now looking into other possibilities ...u
  #49
Old 09-02-2004, 09:16 PM
PeteC's Avatar
According to my manual, 601 circuit is the power line that is "hot in run". Did you have the key in the "run" position? It comes from a 20 amp fuse in the junction box and connects to the brake module on pin 14. No other connections are shown. The drawing number is 42-5 in my CD manual.
Hope this helps,
PeteC
  #50
Old 10-06-2004, 11:28 PM
D.K.L.T.'s Avatar
Unhappy please help
I to have the ABS light problem. I have replaced the rabs sensor and the light still comes on... I did the self-test and got 6 flashes from the abs light... Could some please tell me what the 6 flashes mean? it's a 99 F150 V-6
  #51
Old 12-31-2004, 09:37 PM
kamuelakea's Avatar
I am new to this board.
Want to say thank you to all who contributed to this thread.
My ABS light has been on for about a year and I've been afraid to to into a dealer to have it checked fearing that I would be turned upside down and shaken until all of my spare change was gone.
I read about the likely culprit and so I went to Ford and got the Rear Differential Sensor for 30.00. (I know, the local parts store had it for 8.00 but I didn't wan't to take a chance).
Anyway, it worked.
Thanks a lot!
  #52
Old 01-11-2005, 10:49 AM
bluefishbeagle's Avatar
My brake light and abs light started coming on together after 20 or 30 miles of driving. This problem seemed to start at the same time I noticed a vibration in the drive train. Found a bad u joint at the pinion shaft. Replaced all three u joints and the carrier bearing (two piece drive shaft). Also found bad wheel bearing seal in right rear (full floating axel). Replaced seals on both sides, cleaned up oil soaked shoe on right side but did not replace.
Also changed my diff back to 4.10 since I had the gears given to me by the previous owner, he put 3.55 ratio in since he ran empty a lot. Everything look ok in the diff.
I'm still having the same problem. After driving about 20 miles (or warming up?) my brake light and abs come on at the same time. Shutting the engine off resets everything but the lights then come on much sooner (usally the next stop). Vaccum seems to be ok but I'm going to replace the booster and master cyl (they have 100k on them anyway) and see what happens.
I'll repost after this but if anyone has any ideas I'd appreciate it.
thanks
  #53
Old 01-11-2005, 08:02 PM
Finally found the tech information I needed at autozone.com .... They list all trouble codes and trouble shooting flow charts, diagrams, etc for RABS systems.
That saved the day for me!!! My problem was a code 4. After eliminating the brake light circuts as a problem I focused on the HC unit. I was about 90% sure that I knew about 30% of what I was doing so I replaced the Hydrualic control unit (bought at AutoZone of course).
Bingo, my troubles went away. Thanks AutoZone!!
  #54
Old 02-03-2005, 10:44 AM
AlmostRice's Avatar
<snip>
What vehicle did you use? The autozone site does not show any documents for 97-2002 F150 There looks like a 1996 F150 document that has similar trouble codes and setup.
  #55
Old 02-07-2005, 09:32 AM
4.6_F150's Avatar
I Have a 2000 f150 4x4 with four wheel abs/ disc brakes.Napa part # 530780-up for the rear sensor on the pumpkin $11.36. Mine lasted about a tenth of a mile and the light came on again. Anyone got any ideas???? PLEASE HELP
  #56
Old 02-08-2005, 09:44 AM
My truck is a 1993 F250 with rear only ABS. I did notice that all truck are not listed especially for the late models. However just go back a year at a time until you find your system on and older listed truck. There shouldn't be to much difference.
  #57
Old 02-10-2005, 11:21 PM
sdtsdt's Avatar
Will somebody please post the ABS test procedure or a link to the instructions ... I have a 98 F150 4.6 with Rear ABS ... I have the Brake Light and the ABS Light illuminated ... Thanks
  #58
Old 02-15-2005, 11:57 AM
AlmostRice's Avatar
I found my problem. It was the diff. sensor. It cost $23 with tax from my local dealer. $19+tax from the local parts guy. Some online places had it for $6 or $7, but shipping and handling charges and taxes got it up to $20.
  #59
Old 02-04-2006, 11:58 AM
RHood's Avatar
ABS light
This site is great thank God for it . It has saved me hunders of dollars overs the years.
Got the new sensor put it in light gone!
Part# F85Z-2L373-AC, $22.72 from the dealer.
  #60
Old 02-04-2006, 12:37 PM
Johnny Kay's Avatar
ABS light
Yo, RHood. Agree the website is a BIG PLUS for F150 owners. Glad you got your ABS problem resolved. I just turned in my SCrew on a 2006 Ford Escape XLT 4X4. The ABS light is still on (for almost two years) - - brings a whole new meaning to procrastinating. The dealer will deal with it before he resells the truck. Am now looking for a website for Ford Escape. Happy motoring!! Cheers, Johnny Canuck.
Quick Reply: ABS Light
