Are these wheels clearcoated?
Those appear to be the same wheels I had on my 2001 F150 and YES they were clearcoated. Since clearcoat is basically a clear paint, I used a clearcoat-safe wheel cleaner and regular polish and wax to polish and wax them. They looked real nice after the waxing. Unfortunately the wax seemed to attract more brake dust than normal, but it was easy to get off due to the waxed surface.
Flytrap,
Sorry I didn't originally see your inquiry about getting Bleche White on your wheels.
I don't have good news for you, see my post below. I didn't use it on the wheels, I just got some overspray on them......and have tried everything. What I've been doing is waxing the wheels about every other washing to keep the surface coated. Mine are not too bad, you have to get pretty close to see the spots.
https://www.f150online.com/forums/sh...hreadid=119538
Flytrap,
Here's what I've found and been using since the overspray incident:
https://www.f150online.com/forums/sh...hreadid=122223
Works great!!! Throw the Bleche White.
I have the same wheels and I'm curious can you re apply clear coat to them? Reason being is some toyo took a curve too wide and hit right on the rim and scratched it. I want to praise the toughness of this truck! it knocked my rear end over about 12 inches and that was the only damage I received. as for him he will be replacing a front headlight, fender and ground affects. Also where could i find a new oem replacement wheel besides at the ford stealer? I would then use scratched wheel for my spare tire.
BTW He didn't have insurance and according to the officier was in this country illegaly.
