will harley davidson rims fit on my explorer
Old 10-01-2003 | 03:45 AM
AR02explorerV8's Avatar
Question will harley davidson rims fit on my explorer
Im thinking of buying a set of 20" Harley davidson rims for my 2002 explorer (4 door not sport/sporttrac). I want to know if there is any reason they may not fit properly. Also does anyone know of a such retrofit?
Old 10-01-2003 | 02:18 PM
MitchF150's Avatar
Question
I don't think so........ If the HD is like all the other F150's they use a 5x135mm HUB CENTRIC wheel.
If your Explorer uses the "acorn" type of lug nuts, then it's not hub centric and they won't work, even if the lugs line up.
Old 10-02-2003 | 01:40 PM
powerstroke73's Avatar
I can tell you right now 100% they will not fit. The HDs use 5x135mm pattern and all explorers ever made use 5x4.5". Only way you could do is try to find an aftermarket reporduction of the HD wheels for a 5x4.5" pattern.
