New Ford lug size?? Help!!
They didn`t change the lug size since 1997 on the trucks. You can still get the same ORP wheels on the new 2000`s that came out in 1997.........Lariat#1
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC W/ ORP & Tow Package, Complete Lariat Package Option List ,{APPEARANCE} AVS Carbon Fiber Headlite Covers, Tail Lite Slots & Door Sill Protectors,Owens Fg. Step Boards, Tinted Windows,Ford 2-Piece Bra,20" Chrome Exhaust Tips,A.R.E Bed Cover Lid,Pendaliner Inner Tail Gate Protector,Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection, #1 Ford Truck Plate under glass on Front Bumper, {PERFORMANCE} 4.6L Auto, 3.55LS, 4-Wheel ABS,Platinum 3 Spark Plugs,K&N Air Filter W/ modified stock air box, Tornado Air Man.,WMS Velocity Tube,Dual Exhaust System,Per. Fiction Carbon Mettalic Disc Brake Pads,Goodyear Wrangler A/TS Tires,55 Watt(replacement) Back-up Lites, Pilot 55 watt Back-up Lites on Hitch under truck,Foglites work W/ Brites On , {STEREO} Stock In-Dash Cass. W/6 Disc Changer & 4 Stock Speakers, {SECURITY} Ford Security System W/ Motion Alarm All on same Key Fob, This is LARIAT 1... IN The Great State Of Indiana..........http://hometown.aol.com/terrylariat1...page/auto.html A very Proud Member of ...www.f150online.com
Ford has switched to a larger Stud/Nut during the 2000 model year. The '97 and later wheels may or may not fit the larger studs. If you are using aftermarket wheels, make sure that they are approved for the new studs/nuts. Just because they fit does not mean that they are approved.
'97 F150 XLT SC, 4x2, 4.6, 3.55 LS, 16" cast Al, auto trans, superchip(reg. gas), air box mod, MAF mod, ARE topper, Northern Kentucky
All 2000 F-150's (excluding F-150 equipped with 7-stud wheels and the 7700 payload group), Expeditions and Navigators build after 11/27/99 have the new wheel studs and nuts. The thread diameter increased from 12mm to 14mm and torqued to 150 ft-lb. The new parts are not interchangeable with old, but I don't think the stud pattern has changed.
I checked my wheel stud size last night, at about 11:30PM. My truck was built in October 1999 and does have the smaller 12mm wheel studs.
Has anyone had a problem with the smaller studs? Why the switch to 14mm?
I suspect it could be to handle all the weight of the Expedition, and maybe even the replacement of the "who thought that one up" 7,700 7 lug wheels.
2000 F-150 4x4 SuperCab XLT, 5.4 liter Triton V8 - Windsor, 4R70W automatic, Sterling 9.75" w/3.55 limited slip, towing package, sliding rear window, CD, keyless entry, Amazon Green / Silver.
77 Bronco, 64 Falcon
