Help fitting tires on rims?
Can Someone PLEASE tell me if i can fit 33x12.5's, on 15x7 stock Ford aluminum rims? Could you also give me pros & cons if there are any? Thanks for any info I can get.
95 F-150 XLT 4X4, 4" lift,Leer Cap,Nerf Bars, 33x10.5 BFG AT,B&M shifter plus. (color is black)
They will fit, but the you should probably be running 8 inch wide rims with those tires. It most likely won't do anything, as I have seen trucks with this combo before, and it has worked fine, but what tire companies suggest will happen is the tire will wear out on the inside tread. I have not seen this with a stock rim though.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Ford hvy dty rubber floor mats, Kenwood 10-disk cd changer, Ford bugshield, Chrome Grizzly Wrap Around Push Bar with 2 KC 100w Daylighters, Ventshades, Ford bedliner, cab and bed professionally undercoated, Code Alarm Sure Start RVS remote starter, Ford alarm, Realistic CB with Wilson Little Wil antenna and Astatic power mic, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
