Y2K 150 DIFFERANCES
Y2K 150 DIFFERANCES
This is first post here and I'm glad I found this forum. Just got my 00 F150 5 days ago. It's an XL sport and no tach. Found out about the digital readout from here and that is really heplful the the 5 speed.
The 00 F150 has differance size wheel studs, 14mm compared to the 12mm on the previous. I found out after purchasing a set of 99 takeoffs from the local dealer. The bolt pattern is the same but the center caps will not attach to the larger lug nuts. Should ony be problem with 16" wheels.
00 F150
99 CORVETTE
99 PASSAT(WIFES)
99 HD FXDWG
99 PRIZM(KID'S)
00 F150
99 CORVETTE
99 PASSAT(WIFES)
99 HD FXDWG
99 PRIZM(KID'S)
Welcome to the site. You will find a wealth of information from a many sources that can be quite helpful. You didn't update your signature to say which engine you have but I am sure you will want to consider adding a Superchips soon. Look in the Computer Chips board and contact Mike Troyer when you are ready.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
