Newbie Question
There is a lot more than just those sizes to know about. If you are looking to buy new wheels for your Expy, you need to make sure you get the right off-set and get tires that are matched to the wheels. The offset will affect clearances when turning sharp or make you SUV look like it's on rollerskates with the wheel sticking 3" outside the fenders. A tire that is say less than a 285/60/17 will look like a ballon on a 17x10. On the other hand a 285/60/17 on a 17x6 wheel will give you alot of sidewall flex in cornering and possibly "loose-it". The other numbers you wanted to know about are in the example above
285 is the tire width in Millimeters, 60 is the sidewall height in proportion to the width so 60% of 285 , 17 is the rim size 17" in diameter.
2000 F-150 4x2 XLT Supercab Flairside Toreador Red, 4.2 Auto 3.55 LS axle 275/60R17 Lariat Wheels" Factory CD, Keyless entry, sliding rear window. Slim-Top hard tonneau, K&N, Lund Interceptor
92 4x2 4dr XLT Explorer 121K, 4.0 v6, PaceSetter Exhaust, Wayback seat, Running boards
