Anyone running 20's?
I am really thinking of putting 20 inch rims on my f150 when I finally get it.
For those who have them, is there anything you regret or would have done different?
Please write as much about your experience with them as you can, both good and bad. Based on this hopefully I can make an informed decision before I make any purchases. I've heard that they are not recommended for daily use (show only), what do you think? Can I make it work?
What tire sizes are you running?
What size would you recommend to reduce or eliminate a damaged rim during normal use?
What suspension modifications?
Ride Quality?
How much did yours wheels and tires cost?
Ride Quality?
I ran 20s on a slammed Expedition. I used 285/30-20 P-Zeros and they rode rough. There is not much sidewall to absorb impacts or the small high frequency stuff like rough asphalt. Bending rims was also a major concern.
If you really want 20s I would go with something like the new 305/45-20 Scorpion Zeros or something in the 29" to 30" tall range. They will ride a whole lot better and be more forgiving on your wheels. You also won't need to lower the truck as much to get the same look.
