Wheel weights falling off
Good luck... On my 97 it took 3 trips to different tire stores to find one that supposedly had the right "mag" weights and they swore they would stick... I threw 'em. Finally settled for regular weights on the outside (they stuck) and tape weights on the inside (reg. weights flew off inside) tape weights inside stuck also. Would have had them static balanced (tape weights inside center of wheel) but those damn BFG 285's (great tire...Just take alot of weight to balance) took Soooo much weight I didn't think they would balance properly that way. If all else fails take it to Ford or have them only use the tape weights inside on the centerline of the wheel.
2000 F-150 Lariat S/C 4x4 ORP 5.4L Bright Red/gold
When I had the Goodyears still on, I'd throw at least one weight every time I'd go play in the mud. Thankfully, the guys down at NTB are great, and did them for no charge. Ever since I put the new set on, haven't lost a weight. They must have done something correct.
Scot
97 F150 ORP
Towing/trailer package, 3.55LS
34" Mickey Thompson Baja Belteds, Requisite K&N Airfilter
JVC Kamelon CD Player, CB, bug shield, window shields, and other goodies
Scot
97 F150 ORP
I had the problem too, and balanced my wheels 3 different times before getting disgusted and used tape on weights static balanced on the inside. I clean the area with brakleen and then apply the weights. I have never had a weight come off yet. (That's also how I do all other vehicles with those rims now, and haven't had a come-back yet).
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Ford hvy dty rubber floor mats, Kenwood 10-disk cd changer, Kenwood am/fm cassette head unit, Ford bugshield, Chrome Grizzly Wrap Around Push Bar with 2 KC 100w Daylighters, Ventshades, Ford bedliner, Lund Premier tonneau cover, cab and bed professionally undercoated, Code Alarm Sure Start RVS remote starter, Ford alarm, Realistic CB with Wilson Little Wil antenna and Astatic power mic, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
The correct wheel weight for these rims is a
"T-type" coated wheel weight. These weights will work on all F series and Expedition wheels. Other types of weights will fall off.
I have used the "T type" weights and have had no problems. I guess it also depends how hard and where you drive if they will stay on.
If you use stick on weights, make sure they clean the wheel extra good and they will stay.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
4-wheel disc/ABS,Chestnut/Parchment,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
