Warped Factory Wheel
Old 06-30-2000 | 11:02 PM
Mdell2's Avatar
Unhappy Warped Factory Wheel
Has anyone else had this little malfunction? While driving from N.C. to FL. I heard a rubbing sound. When I stopped to check the noise, I noticed that the inside of the front drivers side wheel was rubbing against the brake assembly (grinding the wheel). I had it towed to ford, they replaced the wheel and it seems fine but what caused it??? They said possibly the wheel warped!
2000 4.2 Long Bed White 5 speed flowmaster 40 with dual 3.5 tips
Old 07-03-2000 | 01:54 AM
Dustoff's Avatar
Post
Was there any vibration before you noticed the noise? Did they replace the rim also??
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
Old 07-06-2000 | 08:13 AM
Mdell2's Avatar
Post
Only after I heard the noise, did it started to vibrate. It was quick. The noise and rthen the vibration.
