No lift... Will 285/75/16 have enough room?
Old 07-06-2000, 12:55 AM
Runningmule1's Avatar
Question No lift... Will 285/75/16 have enough room?
I have been wanting to increase tire size from my stock set-up 265/70/17. I do like to off road occassionally, and I'm curious if a stock suspension provides enough clearance for 285/75/16. Any info and pics would be greatly appreciated...
99 F-150 4x4 sport 5.4, K&N Filter charger, Gibson cat-back, Tubular nerf bars, "Ford" Bra. Bigger Tires and supercharger on the horizon.
Old 07-06-2000, 06:31 PM
mudder's Avatar
Cool
I have 285's on my stock 4x4 and the tires have NEVER rubbed, even off-road. You will be ok, no worries. Here is a couple pics:
Patrick aka Mudder or MR.Daylighter of Arlington Texas (D/FW), member of the Texas Chapter club DAYLIGHTER edition F150 ®, Black 98 S/S S/C F150 4x4 0RP 5.4 V8 3.55ls, Ramsey Pro 8000 hidden winch, Grizzly roll bar, Superwhite Bulbs, 2 Baja back up lights, 2 KC 57 Series 5x7 100 watt long range lights, 8 165 watt KC Daylighters, 4 chrome, 4 black ( with 10 KC's, I come alive at night), Manik grill guard, Westin step bars, Rhino Taillight guards (thanks Pony), Magnum bug shield, Sonic aluminum treadplate 36" tool box, Flowmaster 40 series dual exhaust, Airaid High Flow system, Edelbrock IAS shocks, 285/75/16 BFG AT/S KO, American Racing Baja wheels, personalized plates, Cobra CB radio with 3' whip antenna, Escort Laser/Radar detector, Nokia cell phone, a Mobil Speed Pass on the back window, a F150 Online sticker, and a DAYLIGHTER sticker on the front windshield, and yes, I also have been infected with the infamous door crack. More to come for the Daylighter: JBA headers, superchip, 4 more Daylighters, and a Lighted Ford tailgate logo. If you would like to see pics, email me at mudder46@hotmail.com or see pics at me and pony's website www.angelfire.com/ok3/ponysix8 , and to hear the Flowmaster exhaust http://www.angelfire.com/ok3/ponysix8/images/T005.wav
Also the Moderator of the Ford Trucks vs. GM trucks forum over on fordvschevy.com so check it out.
Check out the Toughest SOB in the WWF crush the Rock's Lincoln: http://www.amta.net/files/sc-2.avi
OH HELL YEAH!
2 BRT 4U "Go ahead, flash your brights at me, see what will happen."
Got light?
[This message has been edited by mudder (edited 07-06-2000).]
Old 07-07-2000, 10:51 PM
abel's Avatar
Question
will 295/75 16s fit on a stock 4x4?
abel
Old 07-08-2000, 10:21 AM
Cool
Mudder!!
Nice truck! Thanks for your help. Have you ever considered a supercharger? I really like my 17" wheels, it's very difficult to find tires for 4x4's with 17 inchers, I was told that the mfg's should be supplying more options in the future, but for now it's very limited. I think I'll just go with 16's.
Old 07-08-2000, 11:11 AM
Dream Merchant's Avatar
Post
"""I was told that the mfg's should be supplying more options in the future, but for now it's very limited"""
i was told this 2 years ago when i started looking at f150 4x4s. the problem is that the 17" stock wheels are only like 7" wide so if BFG were to make bigger wider tires i think they will look a little akward because of the wheel width.
i too am in the process of getting some 285 (or 295) 75-16s on some 16x8 wheels. i drove an Integra before my truck and on the import scene your SUPPOSE to get a larger wheels but now i find myself going down in size to get a better tire selection...
Old 07-11-2000, 03:17 AM
Pat Dantzler's Avatar
Thumbs up
Abel,
My friend has a 2000 150 with the 16" wheels and he has 305/70/16 Goodyear mud- terrains on it. I don't see why you couldn't do the 295's. Personally, I would go with the wider tire-the 305; it looks better, and would stay with a 70 series because if you move to a 75, your speedo will be off. I know because I have 265/75/16 (came with 255/70/16) on mine and it is off about 5mph (70 on speedo=75mph). Anyway, the first #is width of tire, 2nd is an aspect ratio (basically how tall the sidewall is-lower # narrower sidewall, larger #, wider sidewall), and 3rd # is rim diameter. You can change the first# w/out affecting speedo, as long as you have room to go as wide as you want too (you should have room for the 295), 2nd # will affect speedo, and third # can only be changed if you get new rims.
1997 F-150 Lariat X-Cab 4x4, ORP, Tow pack., K&N Filter, Flowmaster Series 40 Delta Flow.
Old 07-11-2000, 08:50 AM
riotrob's Avatar
Exclamation
"You can change the first# w/out affecting speedo."
no no no no no
Pat- Please dont take this the wrong way, but ... no.
The aspect ratio (the second number) is a percentage of the tire's width (the first number). If you increase the width, then you will need to DECREASE the aspect ratio in order to keep the same overall diameter, otherwise the diameter will also increase.
As an example:
A 265/75-16 tire has a width of 265mm, and a sidewall height of 198.75mm (75% of 265). The tire's overall diameter is 16" + 7.82" (198.75mm) + 7.82" = 31.64"
A 285/75-16 tire has a width of 285mm, and a sidewall height of 213.75mm (75% of 285). This tire's overall diameter is 16" + 8.42" (213.75mm) + 8.42" = 32.84"
Old 07-11-2000, 10:17 AM
Matt90GT's Avatar
Post
For the wheel selection, there is some 17x8 and 17x10 wheels out there now. This will definately help the tire manufacturers to make wider tires in the 17" rim size. It has just been slow......
I was going to go with the 16.5 wheels, but it is very limited. more limited than the 17" now, so I decided to stay with the 16s and 285 tires. Should have everything installed tommorrow.
Old 07-11-2000, 01:01 PM
97F150's Avatar
Post
Here's mine with 285's
http://www.zing.com/mypictures/inbox/
1997 F150 XLT 4.6L Auto 4x4 ORP SC 3.55LS Oxford white, Med. Graphite Int. White Faced Gauges,Bed Cap,Superchip,AirRaid,Bug Deflector. Rancho RSX Shocks, 3" Flowmaster 40 series,Bassani Nascar Tip. 285/75/16 BFG AT's, 16x8 Centerline 45 series
[This message has been edited by 97F150 (edited 07-11-2000).]
Old 07-12-2000, 12:32 AM
max mitchell's Avatar
Exclamation
follow riotrob's advice; width, aspect ratio, or a combination of the two change overall height. There has been many posts of incorrect advice about this.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
Old 07-12-2000, 03:32 PM
iridektm's Avatar
Post
I have 285/75R 16 on my '97 and they fit fine. Mine came with 235's. I had to change speedo gears.
'97 F150XL 4.6L 5 spd 4x4
SC, Silver Frost
Clearcoat Metallic,
K&N air filter, Access
Roll-Up Cover, bug
deflector, rear custom
Ford mudflaps, Pioneer
Supertuner CD, 4 Cerwin
Vega Speakers. Future
mods: Spray-in bed liner,
shocks, Superchip,
stainless rocker panel.
* 9/27/99 installed
Factory Ford 60/40 seats
from Sonny's
* 10/13/99 installed
cat-back exhaust system
with dual pipes out back,
a Dynomax Race Magnum
muffler, and 3 1/2'
stainless slash tips.
* 3/9/00 installed BFG AT
285/75R16 on American
Racing Altas 16x8
http://sites.netscape.net/iridektm/homepage
[This message has been edited by iridektm (edited 07-13-2000).]
Old 07-15-2000, 02:11 AM
gofish's Avatar
Post
Iridektm-
How many teeth are on your speedo gear?
Thanks,
fish
Old 07-15-2000, 09:59 AM
Matt90GT's Avatar
Post
Both myself and Iridektm have the 3.55 gears and stock 235 tires. We also both went with 285s. The tranny is a manual, so the stock gear was a red 21 tooth.
We both installed a 19 tooth gear. His was pink, mine was tan. I believe the one I got was for an auto tranny, but it works fine.
Old 07-15-2000, 02:09 PM
Red face
Riotrob,
I never looked at it that way, but I DO see where you're coming from. Thanks for the info. Any idea how much the speedo is off on my friends 2000 4x4- original tires=255/70/16. Replaced them with 305/70/16.
Matt90GT,
Good idea to stay w/the 16". Better tire selection and cheaper (for the most part) than the 16.5 & 17".
Old 07-15-2000, 10:37 PM
Matt90GT's Avatar
Post
The 255 tires are 30.2" tall. The 305s are about 32.8" tall.
If you run a calculator for the tire size and gears, you will be about 6mph off. So you will need one less or better yet, 2 less teeth on the speedo gear. Better to run a few MPH fast than slow.
Quick Reply: No lift... Will 285/75/16 have enough room?
