15" rims fit or not on a 97 4x4
I have been told by someone that they have put 15" rims on there 97 4x4 ORP. I didn't think a 15" rim would fit on the 97 and up.
He even sent a picture. I thought the 16" rims were close to hitting the front caliper.
Can anyone tell me do they fit???
97 150 4x4XLT flareside reg cab 4" warn BLACK DIAMOND suspension lift.
This person had Eagle Alloys 1189 with the
5 by 135mm bolt spacing. He said he got them from desert rat and they said they fit.
I just question how much room there is between the rotors and the wheel.
I was told that the 15" will fit with some grinding on the calipers. It's in the posts but I haven't had time to find it- sorry
'97 F-150 Lariat Ext. Cab 4X4
- White/Silver
- 4.6L, Auto.
- Tinted Windows/Bedmat/Toolbox/Lund Bug Deflector
- 265/75/16 BFGoodrich on polished 16x8 AR-136's
- Cat-back Dual Exhaust
- Polar Bear Grille Guard
kman,
I agree with sdiesel316. 15" will fit, but there's such a little bit of backspacing (3.5") that they'll stick way out. I think another thing about 15" wheels is their load & tire diameter ratings. If the wheel is only rated for 1400-1500lbs & 31" diameter, thats rather limiting. I measured the inside diameter of a stock wheel, its around 14.5" where its over the largest part of the caliper, & there's at the most .125" of clearance between the rim & the caliper.
Also, the inside diameter of an aluminum wheel is tapered with the smaller diameter towards the outside part of the wheel. To make a 15" wheel fit it has to have minimal backspacing to place the largest part of the inside diameter of the rim over the calipers to clear.
I'm not sure how strong a 15" wheel could be & still clear the calipers. You'd have to check the mfr's ratings.
[This message has been edited by d reyes (edited 08-23-2000).]
