Anyone tried 275-70-17's
I was hoping so as well. They would fit nicely in the wheel wells and not rub. From what I can tell going to 315's that Pro-Comp makes would definitely rub. From what I have herd is that BFG and Goodyear are going to expand their selections into this size. But it would be nice to see an F150 with them on.
1999 F150 S.Cab 4x4
Northland Edition,5.4
Off road pkg. Fleetside
Black w/grey int.
1999 F150 S.Cab 4x4
Black w/grey int.
I'm a little concerned that the ORP rims are only 7.5" wide verse the dodge's 8" . But I don't think they would stick out too far. It would be great if BFG. would make the all-terrain in this size, but I don't know if my tires will hold out that long the RTS really stink, with 48,000 miles on them.
I too would like to know about these tires. I'm at 37,000 miles right now(original GY's), and I think I can make it a while yet. But I'm always looking. Who makes the 275's? Before this I hadn't found anything bigger than the 265's unless you went to a nominal dimension tire (33" or so..) I've also been searching for a while on places to buy tires. If I don't go bigger I'd get the Duelers cause I can't afford the BFG's. Thanks for all of the help.
'99 F150 SC Lariat 4x4 Deep Wedgewood Blue with Harvest Gold 2-Tone, Medium Prairie Tan Leather (getting seat repaired), all the factory options (minus captain's chairs, 6 disc cd changer, ford tonnuea and push button 4wd) Polar Bear Brush Guard, Ford Factory Steb Bars, Extang Tonnuea Cover, Duracoat Liner with Rubber Mat, Flowmaster 50 series, Superchip, K&N Filter, Airbox Mod and Silencer Removed, 2 Rockford Fosgate 8"'s and a 250 watts RF amp
I just purchased and installed GY LT275/70/17GS-A Wranglers , They are a top of line tire, retail 160.00 got them at tire rack for 135.00 ea. Only had them for on for 2 days now, but seem to feel/grip the road better, the tread pattern is far superior to the R/Ts that I had and are supposed to be great on wet roads,
98 Lariat 4x4 Pacific green/gray/Billet grill(s)color coded bug shield/side louver/rear window louver/rhino liner/flowmaster dual exhaust/edelbrock shocks/code alarms system/expy console/gara chrome 17x8 wheels/dash mounted GPS/
I decided against this tire because I didn't like the tread, but for anyone else considering the tire...Walmart will order them for $119 each.
1998 F-150 XLT 4x4 Off-Road, 4.6, limited slip, automatic, Red, Supercab, 12-disk cd changer, limo tint, Custom Magnum wrap-around grill guard, Full-length nerf steps with custom brackets.
Hey PAR how do those tires fit & look? Did you put them on the factory ORP rims? Do they stick out very far? Very much taller looking? I believe this tire size is also available in the ATS Goodyear. It will prabably be only a matter of time before BFG makes this size. Thanks for the info.
