Larger Tires, higher axle ratio?
Hi,
I'm about to order a 2001 5.4 4x4 ORP SC and was wondering about the rear axle ratio. I'm planning on putting larger tires onto the truck about 10,000 miles after I get it and was wondering what rear axle I should get. I was planning on the 3.55LS, but I've read in a couple other threads that larger tires reduce the rear axle ratio. I want to keep performance with larger tires, so I'm not sure what to do. Sorry if this is a dumb question, but this will be my first truck and I'm not a genius with trucks.
the only dumb qustion is the one not asked.I have a v-6 and the 3.55-went from 255/70 16 to 265/75 16 and could barely feel power loss.It really depends on how big a tire you want to go to. anything bigger than what I got I think you would need atleast the 3.73 rear end.4x4 trucks have a front and rear axle ratio.the front comes matched to the rear.at least this is my enderstanding of it.If you do aftermarket gears they need to match.
JET air filter
delta tool box
pumpin' stereo
class III reciever hitch
spray in bedliner
headlight covers
custom painted taillight covers
cranked torsion bars 2000 black F150 4x4 sport v-6
lightningcrashz@hotmail.com
JET air filter
delta tool box
pumpin' stereo
spray in bedliner
headlight covers
